79 GL1000 Cafe Racer Build
Hi Everyone, its been a while since I introduced myself last year. Work has been keeping me busy, but not too busy to be sneaking in work on the project wherever I can! I got this GL last summer. Here is a picture after I stripped off all the Vedder parts.
I initially wanted to ride it and work on it continuously but I gave up on that thought and decide to tear it right down.
The water pump had approx 1/8" play and was leaking and rubbing on the housing. You can see the timing belts and tensioners have been done already.
Here it is before I sent it out to be blasted and powder coated..
The deeper I looked at this bike, the more I found out that everything was worn out. I don't believe it was very well maintained. I'm not even sure the engine is the original one for the bike. Should it have the matching frame serial number on it? I initially wanted to ride it and work on it continuously but I gave up on that thought and decide to tear it right down.
Re: 79 GL1000 Cafe Racer Build
Here it is when it came back! Looking good!
I peered into the gas tank with a borescope at work at it was in really good shape internally which was great news. I stripped the exterior and repainted it. The swing arm was media blasted and powder coated. The battery box and fan shroud got done at the same time.
I have to break this into different posts. I think I might be hitting the attachment limit each post. Haha
Here are some more progress pics..
Today I installed the drive shaft back into the swing arm. Bearings were replaced. I picked up an ultrasonic cleaner and cleaned up the hardware for the pivots (among a ton of other stuff!). You can see its installed in the last pic along with the battery box.
Right now I have the final drive rebuilt with new bearings and seals. I want to paint it before I put it on. Both wheels have new bearings and rubber. The front forks are disassembled and being rebuilt. I want to powder coat them before I put them back together. I will post more soon once I get it all together.
Frame and engine will not have the same numbers. They are usually within a few hundred though.
Have you decided to restore or restomod? While the front is off for the pump is a good time to pull the neutral switch and run it through the ulltrasonic cleaner or just replace. Also pull the cover off the sump on the right side, the oil pickup, and clean the bottom of the sump.
Nice work.
1975 GL1000 Restored (sold)
1983 GL1100 Custom (sold)
how many hours did it take to polish the front engine mount /carb shield?
Okay that makes sense then. My frame is 4107073 & engine is 4107087. Thanks Robin!
A restomod I guess? It won't be original but I also don't know the line between restomod and custom.pidjones wrote: ↑Mon May 24, 2021 6:33 am Have you decided to restore or restomod? While the front is off for the pump is a good time to pull the neutral switch and run it through the ulltrasonic cleaner or just replace. Also pull the cover off the sump on the right side, the oil pickup, and clean the bottom of the sump.
Thank you sir!
Its powder coated gloss black like the frame and swing arm. I probably could have taken a better picture!
If you’re in that deep, maybe rebuild the starter clutch ... they can be a problem and they’re way in there ...
After powder coating the frame, you might just stay with light restomod as you have not de-tabbed the frame (which is normally done for a cafe).
Most people "detab" (remove mounting points that won't be used such as passenger footpeg mounts) their frames when building a cafe to save weight (kind of a moot point on a GL) and clean up the look. But, you have already had the frame powder coated.
wow..it looks chrome in the pic.
Oh okay, gotcha. Yeah, I dropped the ball on that.
Restomod it is! Haha. Should this thread be moved then?
It’s pretty glossy. I will get another pic uploaded!
