1977 gl1000
Apinkston
1977 gl1000
Hello, I just signed up for this forum to get some help with my new project bike. Today I got a 1977 GL1000 with 51,000 miles for $200. Definitely has seen better days. It sat outside for at least 4 years and is in need of some major work. Gas tank looked clean from what I could see, air box is clean, and there was water in the carbs that came out when I removed them. The Kickstarter moved the internals so I thought I was ok there. Peeked inside the cylinders and 1/3 are good, but 2/4 are disgusting. Could be rust, could be old gas, all I know for now is it’s orange goop. Thoughts?
Re: 1977 gl1000
If it was me I think I would not waste effort on that head. Numerous used in much better shape are available on Flea bay for less than a hundred. If the carbs had water standing in them that could be a major challenge also. Does the throttle turn freely? If the throttle Shafts are seized that requires a significant bigger effort than just a carb rebuild. We have Carb rebuilders here on this site but if they are seized it make their job much harder.
Re: 1977 gl1000
I will add, if one looks that bad might as well remove them both. I have good rebuildable heads if you're interested. I might still have some that are already rebuilt and ready to bolt on.
I did cringe when I saw all the leaves on top of the engine. A good idea to blow all that off before starting on a job. Especially something like removing the carbs. It just helps keep garbage out of the engine.
Oh yeah, be sure you get new timing belts too.
- dontwantapickle
Re: 1977 gl1000
That does not look good.
Apinkston
Re: 1977 gl1000
So I peeked inside the cylinders and 2/4 look clean inside, still have some oil in there. 1/3 are a little bit dirtier, but not bad. Valves on both sides look good and the oil up in the valves was pure black, but nothing shiny and no debris. The goop on the intakes is likely old gas since it’s wiping away fairly easy, but I want to remove those heads to make sure before I jump on anything.
As for the carbs, on #2 the throttle was stuck tight but I was able to get it loose. It was stuck pretty tight so I’m assuming that’s what was freezing the whole linkage. I haven’t even gotten to 1 and 3 carbs, but it’s not looking good since 4 has a broken vacuum piston. I’ve only ever worked on a 78/79 cb400 so I’m taking my time and working slow to learn this engine.
I may be interested in those heads either rebuilt or not so please don’t sell them right away
Re: 1977 gl1000
As long as there isn't water in the crankcase (I don't mess with rusty gears), it is just work. I sat on my butt with single edge razor blades clamped in hemostats for a couple weeks shaving #1&3 cylinder wall rust on my Hunley. That side has the best compression now!
Apinkston
Re: 1977 gl1000
I don’t believe there’s any water in the case since the cylinders themselves are rust free and the oil in the top end is clean. Right now the Kickstarter will move but it has a lot of resistance and I don’t hear anything move so something is up there. Any ideas on where to start for that?
Apinkston
Re: 1977 gl1000
Any tips to remove the driveshaft from the engine? Getting a pair of snap ring pliers today but the U joint is pretty rusty and may not want to come off so easily
Re: 1977 gl1000
I must hold my mouth right. Never had trouble getting it off. Tie back the boot somehow (without damaging it) and get plenty of light. Then take your time. If really rusted/seized in, you might do well to tap it around a bit with a screwdriver to loosen it.
Apinkston
Re: 1977 gl1000
Any ideas for a stuck sub frame tube? Mine seems to be stuck at the foot peg which doesn’t want to come out
Update: nevermind. I got that peg loose and after more struggle I noticed I skipped the oil filter housing. Got that off and got the engine out. I now have to move my garage around to properly work on the heads. Speaking of heads, how much are you selling them for? It’d be nice to have fresh heads over these ones
- flyin900
Re: 1977 gl1000
Send Robin a PM as people don’t always monitor the threads closely. Once you get the heads off you can better determine the turn over of the engine. It maybe worthwhile to also pull the rear case to access the clutch for an assessment too.
With the engine out now is the time to give all the key items a once over, as when it is back in the frame is not when you want to discover a missed issue.
Current Bikes:
DISPLAY MODELS:
RIDERS AND FUN TOYS:
DISPLAY MODELS:
Apinkston
Re: 1977 gl1000
I was able to get the engine up onto my table thanks to sketchy redneck engineering and got the covers for the belts removed. Seeing lots of red, orange, and white and it’s not looking pretty, but I got my spanner on each wheel and I was able to turn them smoothly but with lots of resistance. Cylinders 2 and 4 made noise, but have not tried turning them more than 1/4 turn. Engine had roughly 4 quarts of oil in it when I drained it, so I’m guessing this is a dry case for the belts.
- flyin900
Re: 1977 gl1000
That looks like it is going to need a some TLC and possibly a rebuild of those belt tensioners. The one is pretty rusty looking there. A good solution for rusted parts is either Metal Rescue or Evaporust which are excellent non toxic rust removers. They clean up rusted parts very well and I highly recommend them. Get the 3.8 liter jug if you can it is better value IMO.
It maybe worth while to take that down to a short block by removing all the front and rear covers and heads to see where your at with that motor.
I would start with the heads to see what the bores look like overall.
Current Bikes:
DISPLAY MODELS:
DISPLAY MODELS:
- Jonesz
Re: 1977 gl1000
Just a thought. Post your location so we know what help might be available. That engine looks very rough and it is just my opinion but you might be far better off to look for a running engine without all the water damage etc. There are folks who have spare engines and it would be nice to get one but without knowing where you are it is hard to figure shipping etc.
Jonesz
1979 Suzuki GS850. Sold
Apinkston
Re: 1977 gl1000
I’m in Sacramento, but I’ll start with the heads tonight and if I have time I’ll remove the starter and clutch to check those. Is there a way I can activate the starter by hooking it up to a battery to see if it even works?
