what does everyone use?
I have several new throttle and clutch cables I want to lube.
Is the specific cable lube the only way to go or is there something else folks use?
I was thinking fluid film.
cable lube
cable lube
Re: cable lube
Depends if the cable has a Teflon liner or not.
Re: cable lube
so far the ones I received don't. if it has teflon I'm leaving it alone.
Re: cable lube
that is correct. If not, I use 3 in one oil.
Re: cable lube
- flyin900
Re: cable lube
There is a specific cable lube oil that I don't have handy for a picture, yet any bike parts seller will have it. FortNine for sure. The one I have is an aerosol can with a mostly green and white label about 1/2 the size of a spray paint rattle can.
I like the little metal cable lube attachment (separate purchase item) that forces the lube into the cables rather than all over you.
Current Bikes:
DISPLAY MODELS:
RIDERS AND FUN TOYS:
DISPLAY MODELS:
Re: cable lube
Backyardbob used to tell the story of his winter maintenance routine. One of the things he did was remove his cables and tape a bag of gear oil on them and let them hang until it came out clean on the other end. Last I talked to him he was over 400,000 miles on his clutch and throttle cables.
Re: cable lube
Whiskerfish wrote: ↑Tue Apr 05, 2022 8:44 pm Backyardbob used to tell the story of his winter maintenance routine. One of the things he did was remove his cables and tape a bag of gear oil on them and let them hang until it came out clean on the other end. Last I talked to him he was over 400,000 miles on his clutch and throttle cables.
I bought the lubing tool..
I'm going to try fluid film. it's great stuff that keeps creeping..
Re: cable lube
I attach a funnel with duct tape, hang the cable up, pour in some clean motor oil and wait for it to work its way through. You can't see it in the pic but I'm pointing at a drop coming out the bottom (you also can't see the garbage can that it is dripping into)
