Brake rotors drilled & machined
dartman1962
Post by dartman1962 »
I just received my brake rotors back from being drilled & machined.
I sent them to Tom @ Truedisk down in Michigan. They turned out Awesome! In my opinion.
I’m also rebuilding all my Master cylinders & calipers with new kits & caliper pistons, brake hose all done last winter.
I am also wondering about a little wear on my caliper brackets where the pads sit, slight groove there.
Not sure if anyone else has ever run into it, and how to possibly fix it.
I have one idea that I am thinking about.
Idea’s welcome!
1975 Honda Goldwing,
2000 Honda Ace Tourer
Let's R&R, Rev it up & ride!
Image Image Image
The day I purchased the loaded wing for the sum of $20.00. Nearly finished 1975 NGW way better naked!. My 2000 1100 Honda Ace Tourer. Next project?
Re: Brake rotors drilled & machined
Very nice …
Gord anim-cheers1
dontwantapickle
Post by dontwantapickle »
brake pad retainer
+1 on the retainer. They often 'got lost' while changing the pads.
dartman1962
I don’t see that retainer listed in the breakdown diagram/fiche.
Is that listed for other years than 1975?
Image Image Image
Sorry, it looks like the shims were put into use on the 78 and later models, which used a different caliper design...
gregforesi
Post by gregforesi »
1. Just ride it.
2. Fill the spots with JB weld and file the spots flush.
or
99. You could have someone TIG weld some aluminum into the spots and finish it flush.
I know which one I'm voting for.
2006 GL1800 (Brutus Maximus)
dontwantapickle
I can only assume that the steel retainers introduced on the 78's were the factory's solution to this very issue.
Steel brake pads moving back and forth across the alloy are sure to cause wear.
If it were bad enough, I could see it causing the brake pads to not slide smoothly and bind.
I would think that filling the low spots with JB weld would not be a good idea,
as it's even softer than the aluminum and would wear even quicker.
Probably the easiest thing to do would be to polish out the wear best you can and carry on.
(although you might have to do it again in another 50 years).
I like #1 …
Gord anim-cheers1
dartman1962
Yes, I thought JB weld too.
I actually have a Brand of Wurth crazy glue that when used with the activator sets up very hard that I’m going to try, as it is not very deep & I think JB weld might not stick properly.
Image Image Image
