Fuel tank removing
Fuel tank removing
Any tips,suggestions that will help do this-82 asp going naked.Need to clean tank.
Thanks
Jim
Thanks
Jim
Jim Murray
1981 gl1100 standard
1981 cb 900c
1981 cb 900c
- hmratbam
Start removing parts until all you have left is the fuel tank!
Seat,rear fender,rear wheel,maybe swingarm,false tank for access to bolts,battery,battery box,maybe more. It ain't easy!
My Album
84 Standard ongoing project
My Album
Best described as giving birth. Once you get all the stuff out of the way you sit on the floor behond the bike and start wiggling!!
just hope there isn't any meconeumWhiskerfish wrote:Best described as giving birth. Once you get all the stuff out of the way you sit on the floor behond the bike and start wiggling!!
Its not that bad, battery box, rear wheel both shocks, seat, fake tank and the ONE bolt holding the tank and you are there.
2 days first time, 45 mins 2nd time.
- Hardware Man
- Cookie
- RIP: 1950-2011
On my bike it was still tight after removing everything listed in the manual. I pulled the two muffler rear support bolts and used a big screwdriver to wedge the muffler down about 3/8 of an inch and it came free.
Q, Yep it is, you get the gold star
- Jay
My daughter was born in meconeum. Had her on Dec. 19 01 and didnt get to bring her home tell the 26. They didnt let us keep her in the room with us and we had to take her to hearing test an all sorts. The people that did the hearing tests never heard of meconeum and didnt know way we needed hearing tests. I told them we were just told to.
She was fine though.
Are there any affects this could have cause?
Don't fix it Customize it!
- Q
Jay wrote:rcmatt007
QQQ
- Jay
- 1CrazyMoFo
I kind of cheat as I'm parting out the wing, so everthing is removed. The main thing I've found is to hit the back/top of the tank with a flat hand and watch the tank move. I've gotten to where they pop out pretty easy. It really doesn't take much force. Dave and I have been thinking of fliming the next tank removel (watch it be a bear).
Peace,
Frank
Peace,
Frank
The truth about Ape Hangers, yes they are very slimming.
- Flat4Ben
Re: Fuel tank removing
Hi I have just had my carbs done by Pistol Pete, And I know I need to clean my tank, Is it the same procedure on a 79 gl1000.
Right now the engine is out, the exhaust are out, rear wheel is out, false tank & false tank suppout are out.
I guess the only thing left would be the battery & battery box, and possibly the rear shocks?
Are there instruction anywhere for this procedure? I have the shop manual but cant find anything about fuel tank removal.
Thanks
Thanks
Flat4Ben AKA Bernard Dubuc
79 GL1000 original (sold)
79 GL1000 being customized
09 BMW R1200RT (sold)
80 Yamaha XJ650
05 VTX 1800 F1
80 Yamaha XJ650
05 VTX 1800 F1
Check Shoptalk, there used to be a vid from crazymofo. I think the link went dead though.
