I have had several entries here in "tech discussions" over the last few months in regards to problems with getting an idling issue resolved.
Basic problem - set idle at 1,000. After engine gets to operating temperature (hot) the idle will rise to about 2,500 and stay there. If throttled up, would return to 2,500. Playing with idle screw was no help even after lowering to 1,000, the first time revved up, it would settle to 2,500.
New ignition, new plugs, new belts, new plug wires, Randakk wheel for dynamic timing, etc, etc.
I rebuilt using Randakk kit / video. Took apart 3 times the last time using a professional ultrasonic. Those carbs were CLEAN and polished. Yet the problem remained. I read and read about what I have termed the 'Mysterious Honda High Idle Problem". Many on this site gave me ideas, suggestions. I pursued them all. You know.... the vacuum leak, timing off, timing belts misaligned, mechanical advance sticking, etc, etc, etc. Nothing changed a thing.
What I finally did after MUCH frustration is send them off to Pistol Pete's shop. I figured this is the first set I've attempted and I need his eyes and experience on those babies !!
He did not rebuild them (no need) but did tweek on butterflies and a couple of things. Putting them back on the bike.....the idle was smoother for sure but ...... guess what......same high idle began to appear as engine got to full operating temperature. Pistol Pete called and walked me through a couple of checks. And.... with an adjustment that took a screwdriver and about 5 seconds.......... HE SOLVED THE ISSUE !!! I would have never discovered what he had me do and his experience was the key. Anyway if anyone ever has this happen, contact me and I'll walk you through it the same he did me (has to do with bending a very specific area on the sync screw setup).
Anyway...... I'm very grateful for Pistol Pete (and Moose) for helping me out.
FINALLY !! Carb problem solved
76 GL1000 LTD
2019 DCT Airbag Tour
Austin, Texas
76 GL1000 LTD
Austin, Texas
- TNTbefree
Re: FINALLY !! Carb problem solved
Glad to hear your issue is solved. Never chimed in on your topic, but I kept an eye on it. Kind of odd... Pistol Pete states "Each Carburetor set is engine synchronized and perfectly balanced on a test engine". And if he did so, why didn't he have the same issue with the carbs at his shop, as you did on your bike? Who knows? Problem solved. That's what matters.
- 77Gowing
OK can you be a little more specific on what exactly was the problem and what exactly was done to solve it?maury wrote:Pistol Pete called and walked me through a couple of checks. And.... with an adjustment that took a screwdriver and about 5 seconds.......... HE SOLVED THE ISSUE !!! (has to do with bending a very specific area on the sync screw setup).
You know, Cause and effect explanation. I want to learn what I can do if the same thing happens to me.
I'm sure other enquiring minds would like to know as well.
Thanks,
"Less is More" Anonymous
77Gowing
1977 GL1000 "O'le Blue." (sold
2014 Yamaha 950 V Star (sold)
77Gowing
Me too77Gowing wrote:maury wrote:Pistol Pete called and walked me through a couple of checks. And.... with an adjustment that took a screwdriver and about 5 seconds.......... HE SOLVED THE ISSUE !!! (has to do with bending a very specific area on the sync screw setup).
Me Too!!
October,2017 BOTM
October,2017 BOTM
- salukispeed
Awesome to hear. It is amazing what experience can bring to odd conditions. Even tho they sync them on an engine it would be very difficult to exactly duplicate every facet of a test drive and heat soak from traffic and such. Well done, Congratz
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
1970 CT 70
The problem was described (I believe) in detail in the first post. Basically...... high idle once bike achieved normal operating temperature (fan cycling).77Gowing wrote:OK can you be a little more specific on what exactly was the problem and what exactly was done to solve it?maury wrote:Pistol Pete called and walked me through a couple of checks. And.... with an adjustment that took a screwdriver and about 5 seconds.......... HE SOLVED THE ISSUE !!! (has to do with bending a very specific area on the sync screw setup).
Thanks,
Pistol Pete first asked if the idle changed when pushing down directly on any of the sync assembly screws. It did, the idle went from 2,500 to 1,000. When I let the pressure off the sync screw top - idle climbed right back up to 2,500. So this is what he had me do....... take a screwdriver, rest it against the side of the carb (just below the vacuum cap) then VERY slightly bend out the upper arm of the "C" shaped tab on the carb sync screw/assembly (See pictures below). If you're not familiar with the sync assembly there is the top tab that the screw passes through with the lock nut on top of it, then below that a spring (with washers in proper position) and the lower tab that is actually shaped like a "C". Do NOT pry on the top tab with the screw going through it, ONLY the bottom "C" shaped tab. When I first did pry on the tab, I could see it flex slightly and I stopped. The idle did not drop from 2,500. At the suggestion of Pete, I again applied a bit more pressure, could see the tab flex again ..... and then...... MAGIC
The sequence he had me use (if I needed to do more was).......
First - Carbs # 2, 4 sync assembly (between carbs # 2 and 4)
Second - Carbs # 1, 3 sync assembly (between carbs # 1 and 3)
Third - Sync assembly that adjusts right side carbs to left side (to the outer side of carb # 4)
I did not have to touch the second and third above at all.
I felt for a long time that there was a binding/sticking somewhere but did not feel, see or know where it might be. My guess is that as the engine heats up the heat causes a slight expansion of the butterflies or sync assembly and then at the sync assembly there is a very slight bind/friction. All I really know is that it worked and I'm thankful after chasing the "Mysterious Honda High Idle" for months.
76 GL1000 LTD
Austin, Texas
76 GL1000 LTD
Austin, Texas
Interesting. With my experiment using V65 carbs on a 1200 air box, I had to bend the sync tabs as well to get an idle low enough.
- 77Gowing
Thanks Maury,
That was exactly the detail I was looking for and thanks for the pics. I am ignorant about the carbs on my bike but will get the Randak video so I can learn about them so this will probably help me some day. Sorry if I sounded critical, but I really wasn't busting your chops. Great Job!
77Gowing
77Gowing
