Trust me, I've been contemplating this issue more than once
I do like the retro look of the instrument cluster and I have invested quite some money into it with a new regulator and the new speedo.
But with that said I have been looking at a more modern one like the motogadget mini: https://motogadget.us/products/motoscope-mini
Feels like I should have bought that before I replaced the other parts
The saying goes like this right?
Hindsight is 20/20
Hindsight is always 20/20...many of us have purchased things, only to repurpose them on something else, and then get something different for the old project.
If you really like the look of the stock cluster, then have a peek at the Magna (V45, V65) tachs. Guessing one can be retrofitted into your cluster, and would look a lot like the original. Quite a bit cheaper than that Mini. Just do your research to know which one will best suit what you want to do.
"Can't see the paint when your looking thru the handlebars..........." -Oldewing "I'd rather Ride than Shine" -RAT Me Too!!
Bike has always had a wobble during sudden changes of speed. Like when letting go of the throttle sharply or hitting uneven asphalt patches or the like.
This has been getting on my nerves and I've even thought about replacing the complete forks at times. All bearings where perfect and I did not find the issue until like two weeks ago.
When I replaced the older wheels with the correct size for my 1982 wing(18"/16") the wobble is completely eliminated. So the other set of rims must have had some sort of imbalance not noticeable other than the steering wobble. Absolutely fantastic to be rid of that crap
