GL 1000 cafe fighter
Norbert R
Re: GL 1000 cafe fighter
#256
Post by Norbert R »
Your frame looks fantastic - good lines to it, the motor looks really nice in the there.
I particularly like the little peak at the top of the rear hoop, nice touch action1
Nulla futuit datum...
1977 GL1000 - BOTM April 2015
Cafe Maximus Build Thread
EHE
#257
Post by EHE »
thanks!
yes my health is okay enough to spend very long hours in the workshop :)
so I'm not complaining at all :)
EHE
#258
Post by EHE »
yesterday I spend hours searching for the right air filter that is big enough en fits in between the carbs and the gastank
this one should just fit in...f
I will have to make a top shielding myself cause the Original K&N one makes it much to heigh. But that will work out just fine.
but to make sure I made a paper dummy
and i think it will really fit... or I will modify the bottom of the gastank to make it fit. Cause now I have about the same amount of aircleaner surface as before with this set of carbs on the sidecar.
this afternoon also picked up a nice set of disc brakes that suit the wheels better (and the one I used to make them fit I had only one piece of laying around)
Norbert R
#259
Post by Norbert R »
That air filter will look good, especially with an EHE cover ;)
Do the bolt holes on the discs line up with the hub, or will you need to modify ?
EHE
#260
Post by EHE »
The bolts line up, the inner diameter of the disc is a little bit bigger then original GL and also the offset, but if you scroll back a few pages you can see i already made adapters for that.
Dimensional this is the same disc as the one with the round holes, just different layout
mhynze
#261
Post by mhynze »
I think some paint stripper would add a nice touch to the tank
1977 GL1000, with GL1100 engine and carbs....in progress
1984 GL1200 Ascenpade gone naked...............in progress
1976 GL1000 1200 Engine, 1200 wheels...........in progress
1983 GL1100 Stock, fully functional!
1982 GL1100 ..................................................in progress
1976 GL1000 Stock resto....................... .........in progress
1978 GL1000....Upgraded...Bad cylinder............in progress
1982 CB900, 83 GL1100 rear end, 2006 gsxr1000 front end, 1200 front wheel..... in progress
1981 CB750k Needs attention.... in progress
The more time I spend on here the farther behind I get
#262
cool beans ehe
EHE
#263
Post by EHE »
how do you mean that about the paint stripping?
EHE
#264
Post by EHE »
I've been working on the electrical things.
first start to build the small battery I've been talking about for already a few years
couldn't find any proper bridge connections so I made my own from 5x1,5 mm cupper strips
lots of soldering, but it seems to work
EHE
#265
Post by EHE »
then try to figure out the best position of the few electrical part I'm going to need to get this baby running.
want to put it all in the seat compartment and as far as I can predict, I think its going to become a very compact cable routing.
the regulator will be mounted on the outside of the seat compartment. nice big cooling surface and in the fresh open air.
Need to find a key switch which also has a start functinon in it (like in a car) and then mount this part also very close to the seat compartment.
#266
Looks great EHE, looking forward to how it works out. This has been a long time coming.
Norbert R
#267
Post by Norbert R »
Nice setup EHE, that battery looks super compact
UK_Andy
#268
Post by UK_Andy »
http://www.ebay.co.uk/itm/Deans-Probars ... SwT6pV1E8C
we used to use these in rc racing to make battery packs
EHE
#269
Post by EHE »
thanks Andy, always handy to know where to find them afterwards ;)
(I'll keep it in mind for the next time. could safe a lot of time, allthough the home made ones work perfect as well :) )
in the meantime she got on her own feet and because of the whole supsension setup was a wild guess... I was happy to notice it feels very wel in balance with the engine in the frame
been puzzling a lot with different headlights and different positions, but this is how I ended.
#270
To me that headlight doesn't go with the rest of the style.
