1200 wheels
BLACKGOLD
My Album: http://www.ngwclub.com/gallery/v/wingmans/BLACKGOLD/
1200 wheels
Post by BLACKGOLD »
does anyone know if 1200 wheels will fit 1100?or will 1000 wheels fit? I'm looking to change what I have now.
Mike
Elvira-1980 GL1100 Custom
Black Betty-2000 HD Electra Glide
"we are on the cutting edge of cocking about" -Richard Hammond
quakeholio
Post by quakeholio »
just wondering why you need to change out the wheels on your wing. I know you can look around for a cb900c wheel, they are the same comstar wheel as the 1100 of the same age. The only thing is that the goldwing for a few years (not sure what years) had a 17 inch wheel in the back and the 900 has 16" for all years.
As to the front tire the cb900c uses a tire size 100/90/19.
I think some other honda's used the same rear wheel as the goldwing, just make sure that the wheel is a shaft drive rear disk brake. If the rear dosn't follow that then you are waisting money. Drum brakes would probably be to difficult to fit onto a bike desined for disk.
Just occured to me that the cx/gl 500/650 might use the same rear wheel. I'm thinking they use disk, but i could be wrong. I know that the cx500, cb900c, and gl1100 use the same piece on the rear end.
Try
NGW Founder
NGW Founder
Re: 1200 wheels
Post by Try »
BLACKGOLD wrote:does anyone know if 1200 wheels will fit 1100?or will 1000 wheels fit? I'm looking to change what I have now.
Sorry, they don't fit.
Try
"84 - GL1200 Standard
anim-cheers1
quakeholio
I think the only way the wheel would fit is by swapping out the complete assembly. The one question that rises up is if the drive shaft is splined the same way. In the end its probably more money into it that it's worth if you have good wheels. If you have bad wheels, look around for other shaft drive bikes built in that age (80-83).
2fer-bob
Lead Member
Lead Member
Post by 2fer-bob »
Blackgold, It depends what you want to do! But a few thing to keep in mind. The width of the rim will limit the width of a tire. If you’re looking to go wide on the rear you will need to trim the outer housing on the shaft. If you go real wide you will need to support the housing or elliminate it all together. The Front you can do just about anything you wish. I had a shaft made on mine and reinstalled a Harley spoked wheel.
Hope this helps.
Bob
2fer-bob
78 chopped
82 I
in Wisconsin
BLACKGOLD
Post by BLACKGOLD »
There isn't any thing wrong with them, I just dont like the styling. I was just hoping that the 1200 cast wheels would fit.
Mike
Try
NGW Founder
NGW Founder
Post by Try »
BLACKGOLD wrote:There isn't any thing wrong with them, I just dont like the styling. I was just hoping that the 1200 cast wheels would fit.
Maybe you can put on a sving arm and a final drive from a
GL1200...
Try
anim-cheers1
Dougal
Post by Dougal »
The '83 model 1100's had similar wheels to the 1200 fitted and they fit straight in.
Dougal
They say WHY?, I say why not.
Boxern
Post by Boxern »
Dougal wrote:The '83 model 1100's had similar wheels to the 1200 fitted and they fit straight in.
Dougal
do you think it will fit on a 78 gl1000?
[img]http://www.nakedgoldwings.com/forum/images/flags/Norway.gif[/img]
1978 gl1000
quakeholio
The final drive is different, so as a guess I would say no. I mentioned that the final drive might be swaped with the wheel, but the problem the is will the final drive fit onto the drive shaft? Can't help you there. Maybe a bike bone yard could help you on that question.
Dougal
Post by Dougal »
To fit the wheels between teh 1000, 1100 and 1200 modles you will need to change teh swinging arm and rear wheelgearbox as well. Also take note of which side teh speedometer drive is on with the front wheel. Most 1000's have teh speedo on the right (not sure about teh KZ/K3), the 1100 and 1200 on the left.
Dougal
BLACKGOLD
Post by BLACKGOLD »
Thanks for the info. I guess I need to find a parts bike, or live with the wheels I have. :roll:
Mike
Victorious1
RIP: 1954-2015
Post by Victorious1 »
If money is no object you could have some custom billet wheels built to your tastes, but, get ready for a mortgage like bill to have them made.
Why not try some paint themes or obtain some sheet stainless steel and form some original deigns that could be integrated with your original wheels. Just be certain that whatever you attach to your wheels is mounted securely and permanently so it can't fly off at speed and have your wheels balanced dynamically before you ride the bike.
Vic
Dougal
Post by Dougal »
If you wish there is another page here that I think gives s link to a web page that describes how to fit the 1100 swinging arm and rear wheel in to the 1000 frame.
BLACKGOLD
Post by BLACKGOLD »
Victorious1 wrote:If money is no object you could have some custom billet wheels built to your tastes, but, get ready for a mortgage like bill have them made
Yeah, would probably be less expensive to buy the donor bike.
Mike
