Rear brakelight switch repair
peteybug
Post by peteybug »
Got a new switch on e-bay cause mine went bad so decided to tear old one apart. Will never buy another. It's an easy fix! First take old one off bike. Then get some fine emery paper or sand paper. There is a small rubber boot at the top peal it back you will see two tabs. Now stand on end and push down on solid surface. This should push it apart.
Now pull it all the way out. You will see two brass or copper prongs and a shaft
Take sand paper or emery cloth an shine up the copper fingers and the ring on shaft you can use some contact cleaner if you have it. Now the one that I had the spring was shot so I took a spring from an ordinary pen and it fit right over shaft. In pic you will see two different units I did this for comparison.
Now just put switch back together and test with a meter or test light and should be good to go.
Thank you for that.
Nicely done.
(One of the pics doesn't show up.)
peteybug
Post by peteybug »
Thanks fixed it I hope
RIP: 1950-2011
Post by Cookie »
Isn't that an odd little switch? Nice job petey.
Great job, another item to add to the "while its out" list!
peteybug
Post by peteybug »
Thanks Cookie!! :oops: Like I said in one of my other posting's ( I hate things that can't be fixed) If I can use a hammer and screwdriver on it I might be able to fix it.
RIP: 1950-2011
Post by Cookie »
I was surprised when mine came back by spraying in contact cleaner but now that I see it apart there is no reson that won't fix a not too corroded one.
AZCycle73
Post by AZCycle73 »
Nicely done... my rear switch is working but sticking "on" until I jiggle it so I was planning on cleaning it. Now I know what to expect. Good idea with the pen spring!
1976 GL1000 - in progress - 70,000 miles - Originally Sulfur Yellow
mooseheadm5
Post by mooseheadm5 »
You also need to clean and lube your brake pedal pivot. Mine did the same thing before I cleaned the crud out of the pivot.
-P
[b][color=blue][url=http://www.ladyada.net/learn/multimeter/]Learn to use a Multimeter, Click here![/url][/color][/b]
frenchyric
Post by frenchyric »
My rear brake peddal would'nt even move when I bought my 79, A lot of wd40 and a little propane torch to heat it with and some elbow grease moving it a little at a time and now the rear brakes work good as almost new :-D Also sprayed the switch with WD-40 and moved it back and forth and it works now too.
Frenchyric
If you pedal is sticking in the slightest I would remove it and clean that pivot point properly and give it a coat of grease. It is a very easy job and does not take long at all. Disconnect the M/C, the Switch, and raise the pedal enought to relieve the spring pressure. Then remove the large cotter pin and slide the pedal off the shaft. I suspect you will find a lot of rust inside the pedal and on the shaft. Clean both of those up with some sand paper and grease it up then put it back together.
frenchyric
It doesnt stick at all anymore and operates really smooth but I am going to do a frame up restoration and slight customizing this winter. I will take step by step pics of the progress and keep them posted. This will be my first bike project and am looking forward to the challange :) I'm sure your and other NGW members advice and knowledge will be very helpful as it has been.
Thanks Rick
Frenchyric
hiddenone
Post by hiddenone »
well done. Emory cloth fixes a lot of electrical problems. :-D
"Our true enemies, as well as our true sources of strength, lie within."
--Willaru Huayta, QUECHUA NATION, PERU
2-76 gl1000's
1-76 gl1000 LTD
1-parts 75 gl1000
clevelandtim
Zinc Member
Zinc Member
Re: Rear brakelight switch repair
Post by clevelandtim »
You just solved the mystery of my constantly on rear brake light! Many thanks!
1983 Honda GL1100
1995 Triumph Speed Triple
1986 Mercury Capri 5.8
BlueThunder
Post by BlueThunder »
Pictures don't show. Anyway the links could be restored?
...Brian
1977 GL1000 - Ox
